Off with Head
Sounds like a good job by Phil, not this Phil , I also let loose on my ports with the old polishing bit fitted to the drill. It seems to make a little difference, I also have re-built the old s****d dizzy which I bought of Paul W, strip down and install new bearing, by the way Paul the bearing was well stuffed too, looked like a just in time replacement!!!
Drove the beat into the garage for the winter will finish it off in the spring cannot wait to try it out next year!!!!
Phil
Beatproducts UK
