hi all
can anyone tell me if they is an English manual available and if so where? as i am needing some very big help with the wiring
cheers
xxJTxx
hi all
cheers
xxJTxx
You can get it on CD from Jason in Oz ,but it will not be in english.
Hey Julia,
If you need a Honda Beat Workshop Manual let us know.
Regards
Jason
hi jason
yep i do need one but i am unsure on how easy it would be to understand a japanese one. my problem is when i put my side light on all okay, but when i put my lights on full i have no back lights nor dash lights and what i need to do is go though the manual and follow it, but if you think it would be able to help me send me your payment details
cheers
xxJTxx
Download English translated wiring diagram from my website.
Beat Wiring diagram
Hi Julia it sounds like the switch is not working because once the side light operate the rear lights and the head lamps should be on. Head lamps are on a different a different circuit and fuse. I would take the cowling of around the columb and try to get into the switch probably and give it a spray of WD40 but more than likely the spring in the switch has died. a 1992 civic head lamp switch will fit ( get it from a scrap yard).
Steve's your man...
hi Steve
thanks for the link,- but i can't seem to open it, all i am getting is a blank page with a little red cross in the top left hand corner, any change your can email me in; julia@ryhill.fsnet.co.uk.
hi jurek
Thanks for that I am going to have a look and the switch, hopefully it will be something as simple as that, I’ll keep you all posted…
xxJTxx
Hi Julia,Originally posted by julia21
hi Steve
Try right clicking the link and selecting 'save target as' and download it to your pc that way.
it's a compressed Zip file with the needed files inside.
Hope this helps
Ady.
HI adrian
just tried it, still not joy any other ideas
cheers
xxJTxx
Hmmm,
I can click normally on steves link and it then asks me wether I want to either open or download the zip file..
Do you have a firewall / antivirus prog running whilst your on the net??
if so, try disabling it whilst downloading the file.
What version of windows are you using?? 98, xp ??
Ady.
Link is working fine, via my pc.
As Adrian says its a Zipped file
Julia, I have emailed you the relevant page of the wiring diagram, lighting circuit.
P.s. A new switch is £106.24
thanks everyone for your help, xter big thanks to Steve who has email me it, I deactivate all my anti virus stuff as suggested by ady and it wouldn't let me connect to the internet, so I have had to turn it all back on again. i will let you all know how i get on
cheers
xxJTxx
hi all,
I'm all lit up now. i did as juerk suggested first and check the fuses first and bingo a blown one....once again thanks for everyone's help.
cheers
xxJTxx
Excelent,
Glad you're all up and running properly again...
Ady.
Any time ..
glad all is OK !!
