Results 1 to 8 of 8
Thread: Beat RPM Restriction
    Hi,
    I still have problem with my beat rpm restriction. Its rpm restrict to 7000 rpm. Also the fuel consumption is not good. I also feel the speed meter show wrong reading. Thanks.
    Ali.
    South Staffs
    Nice to see you back, man!
    Long time no see!!
    Can't help, think ade has same problem still!
    Apr 2004
    UK
    On my CRX the ECU flashes an error code - could it be the same for a Beat? (just an idea)
    Hi,
    Unfortunately nope... well yes you can flash codes but no, none are stored...
    I've still got a couple of ideas to try but since it's still running ok (other than the restriction...) it's not really a priority at the moment.
    if/when I get it sorted, I'll let everyone know.
    Adrian.
    Out of Dublin, Ireland
    What happens at 7000 RPM. Does it just go a far as that and it just won't rev anymore or does it cut you off at 7000 RPM?
    I can't belive you guys still haven't repaired this. I remember something about Adrian swapping ECU's and the problem was still there. Am I right?
    So if its not the ECU then there can only be so many things wrong with it. e.g. sensors or some physical damage(like a faulty mechanical part). Its propably something silly.
    On the crx whats the code that is comming up?
    I have a dream
    Its dont go above 7000 rpm. I dont know what maybe the problem.
    Apr 2004
    UK
    CRX fault was something weird - stoped VTEC working...
    South Staffs
    Wasn't no Vtec a low oil issue quite often?
