Results 1 to 13 of 13
Thread: Fuel pump and main relay replacement part numbers
Threaded View
  1. #3
    I resoldered all the connections on the fuel pump relay PCB and it worked again. Seems it overheats and weakens the joints. I'm sure it clicked but didn't work. This may be a false memory but I remember getting it out was a business. Search for fuel pump relay on here there's a lot of history on this.
    You'll need tin/lead solder.
