Thread: handbrake cable set wanted
    Jun 2009
    Hull, UK
    Long shot but just replaced rh rear caliper thinking it would solve my handbrake problem, but it hasn't. They look to me like they come as a set of two joined to the front pull bar. RH side is slack as anything and won't engage fully. MOT have been kind to me so far but would like to get it fixed.
    New handbrake cables from Honda are discontinued, so you will need to look for a used one from either UK or most probably Japan.
    Each side has an individual cable.
    You may be able to remove the cable and try to work it back and forth to free it up perhaps.
    Nov 2018
    I'm breaking one down in Marlborough, have good use handbrake cables if they're any good?
    Try Speedy Cables London https://speedycables.com/
    Feb 2014
    have a set available if you still need them
    Jun 2009
    Hull, UK
    Quote Originally Posted by Seventynine View Post
    Yes, I do still need them, in fact, I only need one; offside (drivers) 47510-SS1-003, Just failed MOT and even the garage can't free up the old one. Please an you message me with details, cost etc? I'm in Hull.
    Jun 2009
    Hull, UK
    Quote Originally Posted by wild-foamy View Post
