Results 1 to 9 of 9
Thread: Fault icon identity
    Fault icon identity
    Hi All, I'll post a fuller description of trip later.
    I have an intermittent warning light that has started today. It looks like a large circle inside a set of small brackets. Red in colour.
    What is it please?
    Dave
    sounds like brake related?
    low fluid
    ABS sensors etc
    handbrake
    nothing too important obviously
    Oct 2014
    Limerick, Ireland
    As above fluid low or handbrake sensor Id say...
    Cheers I'll check fluid
    Aug 2015
    Tohoku, Japan
    Also check your brake pads before topping up your fluid. I've seen situations where the brake pads were worn down enough to lower the level of brake fluid to trigger the sensor.
    Wha a massive tit I am!!! A mint stopping handbrake sensor cutting out. Mint eaten, problem solved. Cheers
    Jul 2005
    Camberley
    Quote Originally Posted by MAMOOK View Post
    Bon appetit!
    Oct 2014
    Limerick, Ireland
    A tasty solution to a simple problem..
    Should this be added to the list of common Beat faults?
    Jul 2005
    Camberley
    Quote Originally Posted by C-Rex View Post
    I'd say it was quite a fresh solution...
