Thread: Dead Dials on cluster
    Jan 2003
    Cheshire
    Hi Folks,
    I wonder if anyone can give some advice to a total novice who now has both speedo and tacho needles dead on the cluster, both jumped about for a bit and finally died this year. I am wondering if this is a common problem and if there are some simple things I can check? I'm thinking that if I figure out how to get the cluster off I'll open it and a load of little tiny springs and things will pop out and I'll never get it back together again
    Any advice out there for this noob?
    Quote Originally Posted by crguitars View Post
    Hi Folks,
    It's not hard to get the cluster out, and since it's all electronics nothing will pop out at you! Chances are you will find some corroded connections. While you have it out it's worth replacing the little lamps with leds.
    Jan 2003
    Cheshire
    Thanks Steve I think I will take a look in that case.
    Colin
    This is what you will find inside the gauges once you have taken the back off.
    Ribbon cable typr membrain.
    Jan 2003
    Cheshire
    Great thanks for the pic Steve, no little springs and things at all :-)
