Results 1 to 11 of 11
Thread: Brake discs
    Brake discs
    I'm having problems matching discs with the european part #'s I've seen on here.
    If the rear-pads are Civic is it safe to assume the discs are Civic as well? (at least on the rear?)
    The Rear discs are a SR3 number which is a Civic number, For EU market and Canada its from a 1994-1997 civic 2dr (coupe), 3dr, 4dr. Japan built CRX. 4 door Japan built integra.
    Front discs are 1985 era Jazz.
    Thank you very much .. so it looks like it's just the front setup which is mailorder from overseas.
    That helps save a few bucks.
    Jan 2009
    Hey, good info! Thanks!!!
    Honda Acty TN looks like they might use the same pad.
    Dorsetspares lists the APEC PAD610 as being compatible with the Acty as well as the City. Pictures suggest they are the same...might be easy to source in canada with all the mini-truck suppliers.
    You have an Acty don't you uj?
    Jan 2009
    Quote Originally Posted by beatc View Post
    Yes, I have an Acty, and the parts are usually stocked somewhere in Vancouver area. Keep in mine the Acty has front disc's, but rear drums...so I'm assuming the front might swap to a beat?
    I'll see if I can take a photo to compare...
    Confirmed for any Canadians that find this post in the future.
    Rear-pads from CRX Si perfect match
    Rear-discs from 92+ Civic perfect match
    No problems with fitment.
    Front pads seem impossible.
    Front discs are possible with a 3mm hub-spacer .. might be cheaper to mail order. Unless your rotors are really bad they might be up for a machining. I just had mine machined to remove the rust from sitting and there's still enough meat left for another when the time comes. I replaced the rears because the replacements were so cheap it wasn't worth machining.
    Jan 2009
    Hey awesome! Do you have any part numbers?
    What year CRX Si?
    92+ Civic Hatch or Sedan?
    Rear disc: Raybestos 96544
    Rear pads: AutoExtra AXMD374
    Jan 2009
    copy, paste, save as! Thanks, I will hang on to this for when I have to do mine!
    Dec 2008
    Lyttelton, New Zealand
    My notes give 97 Rover 100 Metro front brakes, Rear Lokhead Part # VBD457 Brake Disk EH16621
    Again EBC Pads DP529,
    Any Help??
    David
