Hi
Could someone tell me the correct Battery to use for the Beat?
Voltage - 12V
Capacity - ??????
CCA - ?????
Thanks
Hi
Voltage - 12V
Capacity - ??????
CCA - ?????
Thanks
Looking at the shopmanual with my limited Japanese, in Specifications it says 24Ah. ( I think)
Original Honda Part number for battery is 31500-SJ6-013
JIS code for battery size/type is 28B17R
Spec for a 28B17 Battery
Model 28B17R / L
Capacity 5HR (Ah) 24
Dimensions: length 167 × width 127 × maximum overall height 224
CCA (Amps) 246
RC (min) 38
Fine terminal type
i recently fitted a varta one which fits perfectly in the original holder - hope the spec helps, ive had no probs with it at all.
type: Varta Blue Dynamic A15
Varta code: 540 127 033
Specifications:
Voltage - 12V
Capacity - 40Ah
CCA(EN) - 330A
Dimensions:
187 x 127 x 225
pic of mine: http://www.tado.co.uk/beat-bog/battery.jpg
(forum not uploading pics for some reason!)
I think TADO ment
http://www.tado.co.uk/beat-blog/battery.jpg
Blog not Bog
haha - thanks steve!
been a long day here pulling out dash and carpets!
Well all of the above or ask for one off a Jap import Civic/ Mirage, they are all small and will fit no problem
I have a dream
