Results 1 to 13 of 13
Thread: Parts Parts
    Nov 2006
    Parts Parts
    Turns out I need Piston Rings, Connecting Rod Bearings and an Oil Pan Gasket.
    Anyone know how the parts #s and how much I might have to pay?
    (Need them in Canada) -Cheers
    Also, if I get the Clarion CD cable from somewhere can I connect my IPOD to it? -dave
    Piston ringpart numbers wont be a problem.
    Con rod bearing shells, you will need to get info off of your crank and rods to size them up. (I will dig out the info you need)
    There is no oil pan gasket, its Honda Grey sealer used for nearly all engine block joints.
    This is the info you need to get from your engine parts to size bearings
    http://www.manser42.freeserve.co.uk/Bearings_pub.pdf
    Nov 2006
    bearings
    I found out about no oil pan gasket but I didn't know about the different bearings. I ordered some from Japan and they asked me what colour?
    So I told them either one. Hope I'm not in trouble.
    Thanx much. -d
    There are 7 differant sizes to choose from.
    Nov 2006
    sizes
    Do you mean only one size fits ?
    Only 1 of the 7 sizes will be the correct size for your block/crank combination.
    Others will either be too loose or too tight.
    Nov 2006
    Piston
    My motor is on the floor and here is the list of parts I apparently need:
    -3 X standard ring set
    -oil pick-up tube gasket
    -clutch disk
    -pressure plate
    -throw-out bearing
    -pilot bearing?
    -rear main seal
    -front crank seal
    Spec.- connecting rod torque?
    - main cap torque?
    Does anyone have part #s or the specs?
    Thanks much -dave
    This should help.
    Crank seals and oil tube gasket come in gasket set.
    Nov 2006
    bits and pieces
    Yes that's a great help. I appreciate it very much. Have to get back on the road, can't afford to drive any other car for gas mileage. -d
    Nov 2006
    Thanx
    Thanx for the help Steve got it together with new valve seals and clutch etc. man is she running good and no longer burning any oil.
    Now it's true Love.
    Nov 2006
    Ps
    After 1000 miles the oil is still clear and not burning a drop.
    I only wish it was already Spring.
